69jeepcj
The rear end in my jeep is toast. Lost it the other night. So, it needs replaced or upgraded and im not sure which way to go. right now money is pretty tight, and it seems my options are: 1- Replace the axle with the same 2 piece axle early model dana 44, 2- get rid of the front and rear axles and get 76-86 cj off set amc 20 rear and 30 front, 3- get rid of my spicer18 t-case and get 76-86 model 20 tcase (I think my adapter for the 18 is the same bolt pattern as the dana20 tcase) with centered rear axle and front, 4- just swap front and rear wagie 44,s. Seems like other than swaping in the same axle im going to have to change spring mounts on the frame because the cj and waggie springs are wider, mine are only 1 3/4" wide. I personaly thing the waggie axles would be the best choice but also my be the most expensive so I don't know. what would you guys do in this situation? Thanks
