M mmarsh626 New member Aug 26, 2021 #1 Looking to modify my turn signals into daytime running lights, can someone let me know how this is done? What needs to be bought, thanks Sent from my iPhone using Jeepz.com mobile app
JPNinPA Well-known member Aug 26, 2021 #2 Turn signals will flash. Do you mean marker lights? What year make and model! Never look down on anyone unless you are helping them up - Jesse Jackson
Gennybro Active member Sep 17, 2021 #3 wired my utility trailer, the drivers side light is much weaker then the passenger side, any thoughts how to remedy the situation ?
JPNinPA Well-known member Sep 18, 2021 #4 Check the ground to the light and the socket the light sits in. Never look down on anyone unless you are helping them up - Jesse Jackson
Gennybro Active member Sep 19, 2021 #5 Cool, thanks. I took the bulb out and used sandpaper to clean the socket,which had a lot of rust. Every thing good.
JPNinPA Well-known member Sep 19, 2021 #6 Cool!! Never look down on anyone unless you are helping them up - Jesse Jackson
