I just did this install on my 83 Cj-7. You need to make sure the T-18 bolt pattern is the same as that on the bellhousing you are using. It probably is the same because a lot of them are interchangeable, but you need to check on that. Other than that, you need to install an adapter to the transmission so it will fit with you Dana 300 t-case. (I got mine from Advance Adapters ~$500, they don't give them away). Unless you've taken transmissions apart before, I recommend you bring the adapter and the transmission to a garage or a guy in town who'll put them together for you. The adapter requires taking apart the transmission, and installing a few pieces. Once that's done, it's really straight forward. Unbolt the old transmission, lower it. Jack up the new one, and bolt it in. It took me all weekend to do mine, but was pretty straight forward. Get a buddy to help you, and use a jack because the T-18 is a heavy mutha.
