Track bar installation and rear alignment
scoutermp
I rebuilding my 1999 Wrangler, Installed 2 new coil springs after one brook in the accident. I have installed new upper and lower control arms however the track bar is 2" from its frame mount. Any Ideas on where the back axle aligns with the frame. I am currently only off 3/8" from being equal on each side measuring down from the frame.
Thanks for any ideas on what to look at.
scoutermp
You can cheap out like I did and get a rear track bar bracket:
Amazon.com
or get an adjustable rear trackbar. Either way should work to center the axle under the Jeep.
Pics help a lot.
Is the body on the frame?
To compress the springs to normal height.
Are they aligned? Body mounts not messed up?
Are the springs stock height?
If they are taller you will need an adjustable track bar. In the rear you may need a relocation bracket to keep from hitting the exhaust or tank if lifted 3+ inches.
