blaylock6502
As If u couldn't tell by now my 74 cj5 was kinda pieced together when I got it. I got a used valve cover in an attempt to fix an oil leak. I was getting ready to put it on and I was curious as to what goes in the third hole on the valve cover on a 258. I have the pcv and oil filler cap ( which is another deal All thogether). I was looking at pictures to see which hole was supposed to be the pcv because I have a breather and it is interfering with the oil fill cap removal. It doesn't look to me that it would make a difference which hole the pcv was in as the baffling looks the same and the holes are the same size?? But I looked at some pics of old used engines on craigist and it looks like there is a vacuum hose running to both holes? Also should the pcv have full manifold vacuum?
