Thinking of a lift.... need advice
Jeep#3
I just put 31's on my TJ. They look great but I was thinking of a small spring spacer lift. What about a 1" spacer lift? 1-3/4"? Just need some advice! [addsig]
1076638
i'd suggest 1 3/4"... they are very easy to install and work great[addsig]
1076644
are the tires 10.50 or what? I ask because my buddy has a 97 TJ and when he bought it, it had 31x9.50 on it and it looked rediculous. I looked like a lifted stock Ford Ranger. It had a 1" spacer lift on it and it looked goofy. if you have 31x10.50, I would use the 1 3/4" or maybe 2". he has modified his since then, and now i believe he is running 31x11.50 on it. he does not do much off road though. the more off roading you do, the more space you would probably want between your tires and fender flares. just a little input from me. take it or leave it.[addsig]
1076706
They are 31 X 10.5 . The 1-3/4" wouldn't make it look goofy, would it? Anyone have any pictures of a Jeep with this setup?[addsig]
1076709
It will look fine ...I know jeepsters that will only run 10.50
they think it's better in mud...to each there own...But it will
look fine......... :-D :-D [addsig]
1076749
I'm getting the RE 2" budget boost, which is actually 1 3/4", I'll let you know how it goes, maybe I'll post a picture. I have 31x10.50 stock[addsig]
1076829
You can run 31's with or without the BB..I will try to get
some pics for you from USMPK9. We put one on his jeep :-O :-D [addsig]
1076857
i've got a friend who i am going to talk into the budget boost... but he is afraid to put ANY non-stock item on his cherokee[addsig]
1076899
Where is the Budget Boost sold? How much $? How high of a lift is it?[addsig]
1076900
Check Ebay. They have a Suspension kit that was taken off of a Rubicon. This is Springs and Shocks. Starting at $100. If I wasn't in the middle of another I would be on that.
Rubicon[addsig]
