1051748
1. My baby's oil seems to run halfway between normal and hot, espically when i first start it up. After running it for a while, it goes closer to normal but not all the way. The engine temp and battery are smack on normal. What can I do to bring the oil temp back to normal?
2. The gears from the 4x4 transmission seem to rattle. It sounds like they are timed when you would change gears on a standard (my car is auto). And after 45-40 it rattles constantly. Is there somethign wrong with my 4x4 gears or transmission?
3. My yj seems to loose power going up hills and has a constant rattling while idle. I'm assuming its my cat, but would I need to change my o2 filter when i swap it out?[addsig]
