Sway bar links
birkie48
I have a 98 TJ, with only 41K miles. and I've broken my second sway bar link. No off road driving, (however I do live in Wisconsin and will play a little when we get a heavy snow). They both broke on the top of the link where the ball joint is. I can't understand how they fail under minimal use conditions.
The problem is that the parts are not available through local automotive shops like NAPA, and I don't want to keep replacing them with a light duty factory link. Does anyone have a recommendation where I can get a heavier duty sway bar link? [addsig]
1057190
i'd bet a good machine shop could take care of you...[addsig]
1057195
I took my sway bar off... I don't miss it either... Same for the rear track bar...
Then again, I drive a YJ... I'm not nearly as refined as you TJ owners... :-D [addsig]
1057249
You could try a set of Sway Bar disconnects. I would think they would be heavy duty and if you didnt want to disconnect them you wouldn't have to. Just an idea. [addsig]
