backinblackTJ
After reading about 50 posts in here, i've come to realize i should probably go with at least 3.5" to 4" in my suspension lift. I want to run 33x12.5's. I want it to function well off road as well as on road (i use this as my everyday driver). I also want a good looking Jeep as far as proper clearance but dont want too much space between the well and the wheel. Any suggestions as to what size lift i should go with? Also, i currently have a hard top, and have read that i should go with a heavy duty lift, even though i run it with nothing on it as often as weather allows. I have seen Old Man Emu and Rubicon Express brands mentioned. Are these the best brands to start shopping with, or are there any others out there that are excellent quality kits, can be used in hard core (potentially abusive) situations, and still provide good road suspension? I have read that aftermarket 10x15 rims are the route to go, as long as the proper backspacing is adhered to. Again, is this pretty accurate? My YJ is a 2000 sport with an automatic and the warranty is long gone, but I realize after reading these posts, that just popping a kit in and buying bigger meat is FAR from all i have to consider. Gear changes? Other transmission issues? Extending side flares for the increased tire width.
Are a lot of these issues taken care of depending on the brand of lift you go with? Are the brake lines of particular concern?
As you can tell, I am very new at this, but am fairly capable mechanic as long as i have decent directions that come with a kit. The directions usually do not deal with EVERYTHING that one should consider. I plan on lifting early next year, but wanted to do as much research and planning as i can BEFORE i have it up on jacks and trying to do the work.
Thanks in advance for any info ...
