Spring over Steering setup! Need advice
Jeepin91
new guy here...
got a 91 wrangler with 4" springs. Im adding a spring over kit. I have heard you have to change things like draglink and control rods. I dont know much about ways to get around this or make them. all I know is the kit is like $500.00.
can anyone help me out?
justin[addsig]
1052860
your not going to use you 4in lift springs with the kit are you? if so wow that will be way up there almost 10inches there is a kit in quadatec, that wont require to change any of the angles all are suppost to be presion cut so you wont put you drive shaft in a bind and requires no welding[addsig]
1052877
drop pitman arm, z-bent drag link, or crossover steering... crossover steering is the best option... it puts the drag link and all steering parts back above the spring[addsig]
