Spring Over Axel ?
1076949
right toward the transfercase, then down 3 degrees... the 3 degree drop was to make up for axle wrap... when the jeep is travelling with the axle under torque.. you don't want the pinion too high[addsig]
1076984
still like that to this day... still holding strong[addsig]
1076995
Well that is good to know I might attempt
a SOA on the TX TEASE !!! I will get with you
for more info if I do.... :-D :-D :-D [addsig]
1077013
it is not what I would suggest.... but we pointed the pinion toward the output and dropped the Tcase 1.5 inches... that was 1.5 inches less center clearance... but with the 7 inches we added with the SOA/shackles... the 1.5 was an easy compromise. I would suggest the SYE... but still, I have not found one time where his driveline gave him ANY problems[addsig]
1077025
Sounds good I am running 6" lift right now....so...it will be huge :-O [addsig]
1077027
6" + 5.5" = jhiggins on his rollbar...hehe..... dont try they before you come up here.... trails are a little steep.....haha[addsig]
