Tug-n-pull
OK my son Will or Ranger4x4 was not in the wrong as I had mentioned before. The transfer case was not out of gear after all on his truck. We put it all back togather and the truck will not motovate. Here is what we are up to maybe one of you will be able to help.
The truck was unable to pull it'self. and still is unable to pull out. We droped the drive line and while on the ground we checked the clutch. It is ok so we reinstaled it. Turn the input shaft to the transmision and put the transmission in gear and the rear shaft turns along with it. Put the transfer in 4 hi and both shafts trun as you turn the input shaft. Put it into 4 lo and the same thing. all good.
Button it up to the engin and reattach everything and start it up put it in gear and let out on the clutch and nothing happens. can shift with motor running from 1 thru 5 and even reverse with out clutch and or in 2 4hi or 4 lo. What can be the problem here I just do not get it! tug
