Smittybuilt ext soft top
rci1013
I have a 2008 Wrangler Unlimited JK and I bought a 2015 Smittybuilt extended top 94535f or it. I also bought the 2015 OEM soft top for it too! But I cannot get the extended top to stretch out over the top of my Jeep. Heat doesn't work, the weight from rather large friends of mine doesn't work. I called Smittybuilt to see if the width of the Jeeps were different. I also asked if the "added frame" pieces that I screwed to the Jeep were different from the 2008 to the 2015. They said it's all the same. I don't get it!
Check smittybuilt website. Are you sure you have 94535 and not 94635??
One is 2007-2018 the other 2010-2018 so something is different.
https://www.smittybilt.com/docs/installation/94535.pdf
What is the f in the part number for?
Maybe s pic of where it is not fitting over.
My too like that only goes oner the roll bars a nd not the door frames. So when it rains it drips into the jeep.
