laydbak_guy
Hey all, maybe someone can help me here. I got a used YJ (87 4.2L 5spd) in November. Already had to replace the motor (read put new everything under the hood), but kept it with the stock 4.2. The problem is that since the new motor, I've been having shifting problems once it warms up. I don't know if this is due to the change in the seasons or not, but read on. I did replace the clutch, pressure plate and slave while I had it apart. Since then, I chucked a U-joint and while I had the transmission out to have the crack that it put in my T-case repaired, I changed the slave again. I'm still having the probs. Everything is new in the clutch assy from the master all the way out. What's the fix?
