shifter
far_right
ok i know this sounds stupid, but how do you get the shifter knob off the transmission, and t-case shifter... i figured there was a screw or something but there are just two flat spot and i tried screwing them off but it didnt work...
1046943
on my 91 yj you have to take a wrench and then use your hand and turn in opposite directions on the metal piece that is below the knob, not sure about a CJ-5 tho[addsig]
1047034
Never done this... but if you try Quik's method... make sure you don't twist the stick. have rubber coated vise grips to keep it still while you turn the top. I had a friend who damaged his transmission by twisting the stick too much. [addsig]
1047041
yeah i thought about that, thats why i didnt get too violent w/ it like i tend to do w/ most mechanical things.....
1047062
no, on my 91 YJ there is a metal piece at the base of the shifter knob, its got 2 flat sides that you can fit a wrench over and twist that one way, and the shift knob the other way, you dont actually twist the stick of the transmission....but thats on my YJ, i dont know what the CJ5's is like[addsig]
