Tyler Bates
I found a 99 tj in a field and surprisingly I got it for 300 dollars if you can believe that and it only has 50k miles it has a litle front end damage which is why its sitting but it had no key so in order to turn it to load it on the Trailor I had to break the ignition so when I got home i put a battery in and tried to crank it and the alarm was going off so it won't let me start it is their any way to by pass this or do I have to get it reset from the factory
