Baseline 4x4
Now, with the NEW All-Terrain Flat Fender Flares from Rugged Ridge you can add a bigger tire option for a true off road look. You can also use in combination with a suspension lift for maximum off road performance. These exciting new flares are out-of-the-box ready to turn your street Jeep into an off road machine. By removing your original flares and replacing them with these high clearance designs, you can run larger tires without interference from the flare. The ability to run a larger tire with little or no suspension lift means a “lower center of gravity†making your JK more stable, yet you still get greater ground clearance necessary for off road. With 1.5 inches less coverage in the front and 1 inch less in the rear these flares are slightly narrower than factory, yet still maintain proper tire coverage and aggressive looks. Constructed of a flexible UV treated high impact thermoplastic, these flares are designed for the trail and create a whole new look for your JK. Easy to install, these flares replace your factory flares, attaching to the factory mounting points with no drilling. Simply remove your original flares and add on the All Terrain flares. The kit also includes easy to install mounting brackets that allow you to relocate and use the existing factory side marker lights. The All Terrain Flat Fender Flare is the hottest looking, most functional Off Road Flare available for your JK! Finally, because no cutting or drilling is required, if you ever want to switch back to your original factory flares, there’s no problem!
11620.10 - Rugged Ridge All Terrain Flat Fenders, 07-10 Jeep JK Wrangler, Textured Black
Free Shipping on all orders over $199!
Tony Feichter
Jeep Parts and Accessories
Baseline 4x4 Outfitters
1-866-554-5946 Toll Free!
260-636-7565
www.baseline4x4.com Jeep Parts and Accessories
TonyFeichter@baseline4x4.com
FREE SHIPPING ON THESE FLARES.
Tony Feichter
260-636-7565
