Still curious: Anyone do this bypass? If so how's it working? Any scary moments, issues?
Also the Jeep manual says to operate the stock oem locker switch: "push once to lock the rear dif, push a 2nd time to lock the front dif". So, if the bypass switch is on, will the oem switch work to select front & rear still independently, or are both dif's @ full lock only?
