highheelsonwheels
Jeep restorers....
Did it ever crossed your mind that while you're restoring your jeep, you find that a lot of parts corrode easily and you can't restore them and instead you have to find it a replacement? But then, is the jeep still called an original even if there are reproduced parts?
Ok, so here's the thought:
How do we establish if a jeep is a "Restored Original" or a "Reproduction"?
When do you consider it an original; if it solely has original parts? Or do you still consider it original even if there are small parts replaced in it?
What makes the jeep "original"? Is it the body, the chassis, or what else..? (Like, take it out and it will no longer be considered original. Or there's an exception for which parts are replaced?)
