Rearend Noise
93JGC
Hey guys, having some trouble with my 93 Grand Cherokee. It only happens when I start accelerating slowly while turning, if I keep going slow it keeps happening until I complete the turn then its fine. It sounds almost like rubber being squished, kinda hard to explain it. Thanks for any help.
From your description of the symptom, it's likely the limited slip clutches is what your hearing. Service the rear axle with new fluid and friction modifier. Road test for at least 6 miles then find an area where you can do some slow figure 8's to get the friction modifier(Limited slip additive) to completely cover the clutch pack in the differential.
