Quick question on Disconnects
palehawaiian
I have a stock sway bar and endlinks and wanted to put pins in like this.
Jeep Homemade Swaybar Disconnects
My question is with a lift can i do this with my stock endlinks. I am worried that if i disconnect the links that they are under pressure cause of the lift. If i disconnect them will i be able to get them back together?
Any help would be appreciated.
Depends on how much lift you go with. The swaybar and swaybar links will pivot to where you can line up the holes to slip the pins in, granted that your jeep is in a leveled ground so both sides will line up.
