JohnBoy72 New member Jun 9, 2014 #1 What's a good brand of spark plug wires and plugs to use on my yj?
JPNinPA Well-known member Jun 9, 2014 #2 For plugs you need single platinum. Double platinum and iridium will work but cost more. Champion or auto lite. The auto lite APP995's are common. Can't comment on wires.
carnuck New member Jun 10, 2014 #3 Depends which motor/year. I run NGK BKR6EK plugs with carb and upgrade the ignition coil.
J jps4jeep Super Moderator Jun 10, 2014 #5 As long as they are properly gapped, I'll run any plug. I find that about 60% of the time, a pregapped plug is not gapped properly. Also stock wires are fine.
T Turbogus Active member Jun 24, 2014 #6 I like Autolite plugs but for all other ignition products I use Standard and or Blue Streak. A+++
