Track bar ajustment?
Just got a belt to fit my York compressor and fired it up for the first time. Seems there's a lot of oil coming out the discharge outlet. Filled half the bowl of my oil seperator. I've been told by a lot of people that Yorks pass very little oil through the discharge. I have it mounted on it's side and the suction is on top. I've also been told that by mounting the York on it's side, it'll pass a lot more oil through the discharge vs. mounting it straight upright. Is this true or is there something wrong with my York? I'm pretty sure I have the oil at the correct level...could overfilling it cause this? If there's a problem with my York, are rebuild kits available and do they cost much? Is it possible to run the drain on my seperator into the oil fill hole of my York or is the crankcase under pressure? Thanks.
