I've bled the clutch on a 1986 fiero se v6 (the car before the Vette), and i found it to be quite simple. On the top of the slave cylinder there is a tit, just like on the brakes. Loosen the tit about 2 turns, press the clutch down, tighten the tit, then let go of the clutch pedal. Repeat this process severavl times, checking level frquently. The first time i did this i had to get another slave cylinder, which brings me to another point, do not overtighten the tit. I had to get a new slave cylinder, which was cast instead of rolled. worked the same, all that matters. i still have the haynes manual, never used it much, i'll check it tonight to make sure i'm right, but that's how i did it and the clutch felt great. good luck.
that's my roommate there. took a while to get to it.
