Hey mr. Turbogus ! Yeah , I'm not fond of the term " dizzy" in terms of a distributor either . Since your inspection of the distributor drive gear and cam drive gear yielded satisfactory , I cannot see how a distributor would have "walked" out of time on its own . I'm sure you will get the engine back to,preliminary timing TDC #1 compression stroke and set the rotor accordingly and give another twist of the key . Electronic ignition is funny that way when cylinders are crossed. But the only way an engine could even start 180 degrees out is if the distributor was advanced or retarded enough to start the sequence on the correct cylinder or closest to it. It would be like pulling the distributor and turning the rotor shaft 180 degrees back to,correct it. It amazes me you had the engine running well in this condition. Can we blame the engine builder ? Did they break the engine in to turn key customer delivery condition ? I know of no way other than incorrect install or if the hold down let the distributor hop,out while running . But for the gear to mesh exactly 180 degrees by jumping out of the engine isn't possible . So I'll just say I agree with you to replant the distributor as per standard install as we have be raised from pups and been doing since then and expect it to fire as we always have . This is very interest oping however . As a last note , it will also pay to make certain that valve timing is correct as per your last statement in your post. I would want to be sure too .
