After about 1980, maybe a few years later, Dodge offered synthetic as an option. They did recommend, using a break in oil, then changing to synthetic. In the late 80´s, Chevy could be ordered, from the factory, with synthetic oil, no break in oil, recommendations. My 88 XJ has a tag in the motor compartment, looks factory, says use only synthetic oil.
Darned if I know. But I doubt Mobile, would produce, an oil, that was gonna cause major complaints and it would still be in use twenty years later. Mechanics may be slow, but they arn´t stupid, the word would get around. Cam manufacturers would sometimes post a disclaimer, with there product, not to use a synthetic for break in. Then would offer special cam grease or oil, always thought they just wanted to sell there oil/coating. Most engine builders I know, old school, would use a Moly B coating on new cams, a whole lot slicker, than oil or grease.
Castrol always semed to be a pretty good oil, but looking at the color it seemed a bit better refined than most. The newer Mobile 1, isn´t as clear as it used to be (I opened up a ten year old can the other day). Mobile may have already made some adjustments.
