Is it the 90 in you're info? They have a closed coolant system and you get air bubbles in them and run hot. You have to burp them. Could be a the fan or timing. When you replaced the radiator did you clean the gunk out of the condensor, it may be blocking air flow and they catch all the garbage going down the road or trail.
