76quadtrac
After getting off the ice last night I noticed smell of oil, I checked the gauges and the oil pressure gauge showed less than 10 lbs. of pressure. More like 4 or 5 to be exact. The factory gauge has always showed a low pressure. When we got home I crawled underneath and there is oil everywhere.
	  It doesn't leak very much when its sitting so I am assuming that this only happens while driving? I checked the fluids and they are all ok. It looks like its comming from the front seal or the front of the oil pan. Would the oil pressure gauge show a low reading if the seal is out? How tough is it to replace seal, should oil pump be replaced also, sending unit? How spendy is this going to be?
	 I was stuck yesterday and had to make the beast work, I am wondering if that didn' take the seal out.(yes the Jeep was stuck)Only the second time!!! Any Info on problems would be great. 1976 wagoneer w/401 Gravel Crusher[addsig]
