oil leak ?? help
striperman101
Just got a 1990 jeep yj , put in new clutch , hoses , belts , motor mounts , trans mounts , engine gaskets - valve cover - oil pan - distributor gasket - ect. Oil leaks out of top of the distributor - weep hole . Got a new distributor , same thing . I checked crankcase vent for blockage . anyone ever seen this before ???????
Make certain that your PCV is functioning and the PVC valve when removed rattles when you shake it. Lack of Positive Crankcase Ventilation can cause overpressurization within the motor, and oil will find least point of resistance to escape.
