GlenwoodCJ7
Well, your white wires will be your heater wires, the gray will be your ground, and the black is your signal wire to your ecm. When your engine is warmed up, you should get .01-.09v on the signal wire. You are showing 4.14-4.13 signal. I would double check with the mfg of your sensor to validate those numbers as their sensors might be a little different.
A few other things to look at... all of which can show o2 sensor defective
Overall system voltage
Coolant sensor
TPS
MAP sensor
Coolant sensor
TPS
MAP sensor
