1041368
I have an '87 Wrangler with a NV4500 transmission in it. Can some one answer the following questions?
1. It rattles a lot when idling and quiets down when I push in the clutch. Is that normal?
2. While driving and the RPMs get high, there is a very loud, almost deafening, rattle coming from the transmission or clutch or bearing. I don't know which. The clutch grabs really well, like new. Any idea?
3. How do I check the level of the fluid in the NV4500? Also, I want to change the fluid without removing the unit, is this possible?
Thanks!
Steve[addsig]
Thanks!
Steve[addsig]
