nutter bypass??
1987yj
i own a 1987 yj and was wondering if i need all these vacume lines, there seem to be alot of them missing already and the ore i plug the better it seems to want to run. i have seen on here people talking of a nutter bypass, has anyone heard of this if so can you explain?? y jeep has an 6cyl 4.2 with 2brl carb...5 speed trans
hard top rack
Hello 1987yj,
Web articles describing the "Nutter Bypass" abound, but here is a hyper-link to an article that explains the "whys" and 'hows" of the Nutter Bypass.
http://www.off-road.com/jeep/jnutter1.htm
NB: The author wrote the article with CJs in mind. He stated (paragraph 3) that he did not know if the technique was applicable to the YJ Jeep models. I too must plead ignorance on that score.
If the above article does not suffice, a Google search on "Nutter Bypass" will turn up several hits on the topic.
I hope this proves helpful.
Regards,
Gadget
how to.... go muddin (or wheelin... whatever you call it)
The nutter works great. But it won't eliminate your vac lines.
I have the same jeep you do, just rebuilt the motor. and did the nutter thing, as well as the TFI, I also gutted it as far as the vac lines are concerned, **leave the advance though, and be sure to plug every port you pull. Mine like yours runs better than it did with them.
I know I could have just replaced all of them, and the various diaphrams and splits etc, but after realizing how tedious a job it would have been, I decided F#!K that!!
--Tedious because all those lines and air hoses have specific inner diameters, and i beleive even
lengths(not sure on the lengths bit) You cant just go to NAPA and get 6' of hose and begin replacing them with a knife and matching old hose.
hope that helps in one way or another.
BTW--I happen to live in New Hampshire where there are close to zero emissions laws, and no emissions testing.
