n3rdpwdr
TBI is a throttle body injection, it looks very similar to a carb however works like fuel injection. An ECM is the computer that controls all of the electronics for the motor. A lot of times this issue that you are having is caused by a sensor on the TBI (MAP, TPS,), failing ECM, a wire short or break between the two, or fuel line. If you have taken the fuel line apart at the filter and turned the key on (don't crank the engine, just turn key to on) and get a spray of fuel out of the line replace the filter. If that does not fix it then what I would do is take a can of electronic connection cleaner and clean all of the connectors that attach to the TBI. If that doesn't fix it then I would take a one gal. fuel jug and try to keep the engine running by TRICKLING fuel into the TBI. If you can keep it running that way then you probably need to start replacing the sensors on the TBI. Start with the MAP sensor. This is the one responsible for fuel air mixture and does the "choke" function of the TBI.
