GenRight Off Road
GenRight's first product was a YJ gas tank. Tony was wheeling his YJ and the gas tank was becoming the limiting factor of his suspension. So he designed and built his own gas tank. Others saw it and asked for one and GenRight was born.
It's been several years since we have updated our YJ and TJ/LJ tanks and we now have new versions of each with even greater capacity. And some of you may not know that we have a JK tank that increases capacity to 45 gallons!!!
If you're ordering from our website, use code "grchrish" and receive 10% off all GenRight products!!
This is the NEW 23 Gallon GenRight Crawler™ COMP Gas Tank to fit a Jeep YJ (1987-1995). It is specifically designed to allow for more clearance between the rear axle and the gas tank so you can lengthen your Jeep's wheelbase up to 7" of rear axle stretch with a Dana 44 and 6" of stretch with a Rock Jock 70!.
Never hassle with transporting and transferring gas from gas cans again with the GenRight JK Extended Range additional tank!
The GenRight Extended Range Tank will give you a 600 mile range! The 20 gallon extra tank increases your total capacity in a 4 door JK to 45 gallons!
The nice part is you will not notice the extra gas tank since it is mounted under the body in the very rear of the vehicle and fills through the stock gas cap.
It was specifically designed to be mounted under the rear cargo area of a Jeep JK so you can keep the center of gravity low!
This tank follows in a line of innovative and trail proven heavy duty gas tanks produced by GenRight.
The tank is not a "transfer tank" it is a completely redundant tank with it's own fuel pump that is switched by you from the dash. Both tanks tie back into the factory fuel and emissions equipment so you won't get any check engine light or have computer issues.
All the tanks include a foam liner between the tank and the skid.
Find info on these and all our other gas tanks here: Jeep Gas Tanks Fuel Tanks Fuel Cells Container TJ LJ YJ JK CY XJ Stretch
