Need Some HELP
islandguy89
OK when i start me jeep i have this Black liquid that is comming out of my exhaust i am not sure what it is or if it is doing any damage but it is staining the hell out of my garage floor i am not sure if it is oil or what i did an oil change and that hasent helped about 3 months ago i replaced the carb it had a carter on it now it has a motorcraft 2100 and it was leaking this black stuff before i swaped the carb the oil pressure is fine it is just leaking this black liquid out of the tail pipe and i has a little bit of blue smoke comming out with it i noticed when i changed my air filter that i have some blow by b/c there was oil in the air filter i cleaned that and still nothing if anybody can help let me know thanx
Black liquid or is it soot with condensation and goes away after the engine reaches its normal operating temp.. Blue smoke out the pipe indicates a blow by. Could be caused by worn piston rings, worn valve seals and or guides or a bad PCV.
I get that from my 914, because it runs so rich. In my case it's unburned gas coming out the exhaust. Does it look like black dots that come out the tailpipe?
I'm goingwith SteelHeadz. Soot + Condensation = Black "Liquid". How old is the cat? Is it doing it's job anymore? Little clogged up maybe? Blow-by should still be burnt up on ignition. Hense SteelHeadz, "blue smoke". But, it should do it constantly, and not be liquid in form.
Plus with blow by on a Jeep I6 they tend to start puking oil out of the PVC valve. Don’t know how you set up the MC 2100 but if the line is still connected to the air intake it will soil both the intake and filter with oil. They still run that way for a long time but make quite a mess in the driveway.
I think it’s just soot & condensation too.
Often quoted on tailpipe exhaust color;
Black = fuel (running rich)
Blue = Oil burning
White = Coolant/Water
Sparkly funny multi color = Someone put those creosote makin' fireplace crystals in your exhaust system.;)
