alabama cj7 fan 1986
I am trying to get the performance back in my CJ. I have rebuilt the motor, removed all emission stuff as well as the computer. I have a new carb w/o stepper motor, and the distributor is tied into the ignition module directly. It will run fine and starts great but on the road in 4th gear after about 60 mph the power falls off and the more throttle you apply the worse it gets. When I back off the engine comes back but it acts like it hits a limiter. I have set the timing at about 19 BTDC and the advance works to provide about 20 more degrees as rpm builds. it still has the stock distributor but all new guts. The ign module is new as is the carb. I think I have the vac adv conected right but am not sure. i am not connected below the carb but in to a nipple on the left side toward the head in the middle of the carb body. when I connect the dist port to the port below the carb body on the manifold rpm increases a lot.
I just don't trust it to drive to work yet.
Thanks
Thanks
