I broke down and took my wife's 2012 to the shop for some AC work. They replaced everything (compressor, condenser, and others), until there was only the cooling fan left. They also mentioned that I needed a water pump. I decided I could do these two things on my own.
So, I've gotten the water pump and cooling fans in, however the issue is that the fans ever come on. I can get the truck up to temp, and turn the AC on, and the fans don't come one. I put 12v on the old fans - they spun, so I tried hooking them up, with no luck either.
I've checked the two under-hood fuses, and swapped the relays with no luck. When it idles, I can feel the radiator get pretty hot (feel heat coming off)
Any thoughts? Should I have purged the cooling system of air somehow, and the lack of pressure would keep the fans from coming on? All I did was remove water pump, replace, then top off fluid.
