There's also the option to build a stroker with your current engine or a donor 4.0L, or to buy a stroker crate motor. This saves money on adapters and having to replace the transmission and transfer case, and gets you into v8 power range.
If you go with a v8, grab the transmission, transfer case, and wiring harness from the donor vehicle to save big bucks on adapters.
