bryanjeep said:What do you guys think? Should I spray paint the engine compartment black while it is easy to get to. The white paint isn't too bad, it is just stained from Mississippi mud. I am too damn lazy to sand the old white paint down. Is it worth the time and sand it down to put some black paint on it?
yeah i agree, not on the green part, i mean nothing wrong with green, but its your jeep. do it whatever color you want. but like you said, you got the engine compartment empty right now, and you can easily get to it, seems to me like you're not going to get a much easier opportunity than this.Saurian said:I'd do it green, but that is just me. I like green. GREEN!!!
Up to you; if you've got the time, why not? Just use right paint; knew someone who did the inside of his hood, paint caught fire from heat in engine compartment...
Paintit the same color as the mud, then there will never be a problem seeing it again!bryanjeep said:What do you guys think? Should I spray paint the engine compartment black while it is easy to get to. The white paint isn't too bad, it is just stained from Mississippi mud. I am too damn lazy to sand the old white paint down. Is it worth the time and sand it down to put some black paint on it?
