I seem to have a hard time shifting gears or even getting into gear. Please help!!!!!. At a dead stop I will have trouble going into first gear. Idoesnt want to go into gear, almost as if something is blocking it from going in. I have to put the jeep in reverse or in 2nd gear to get it to move a little so that it will go into 1st. The gears grind as I shift through them and they grind when I down shift. I have replaced the pilot bushing, the clutch, the pressure plate, the flex plate and the internal slave cylinder and I still had the same problem. This morning I replaced the master cylinder and bled the system 3 times to make sure I got all the air out. I'm still having the same problem. I don't know what else to do. I checked the to see if the internal slave was leaking but the bellhousing is dry and I'm not losing any clutch fluid. What could be the problem? I also changed the transmission fluid when I installed the clutch kit. I also checked to make sure that I have enough transmission fluid. Please help as hearing the gears grind is making me want to drive the jeep less and less. What should I do or what should I look for? Sorry for taking so long. this is just really stressing me out.
