Looseing Fluid from rear of transfercase!
Tug-n-pull
OK I put in a new output rear seal in and still have a leak in the rear of the transfer. It is not bad but it slings on the bottom of the Jeep body. It looks like it is comeing out all around the slip yoke. Any Ideas? Tug[addsig]
1067688
when you put in the seal... was everything clean? you might have a problem with an inner seal or bearing as well[addsig]
1067729
Your slip yoke may be shot, check for play by trying to wobble the slip yoke on the splined shaft. If it's shot, it's ruining the seal after installation.[addsig]
