Looking to re-gear and hoping for suggestions.
TerryMason
Administrator
Staff member
I'm looking to change out the 3.73 gears in my 2005 Jeep TJ. It has the 4.0L and the 42RLE auto trans. I currently have 33s, and may upgrade to 35s in the future (but this isn't set in stone).
I've got a dana 30 with a lunchbox locker in the front, and a ford 8.8 with a factory limited slip in the rear.
I've been doing research, and I've found a couple of sites that say 5.13s are where I want to be, but others say 4.88s would be ideal. Any opinions on what would work best for my mostly street, offroad twice a year Jeep?
32s with 4.10 is awrsome on our 4.0/42rle.
I would bet 4.88s make 33s spin easily, like the 4.10 does on the 32s. Maybe even easier.
For 35s though, i would get the 5.13
How fast do you need to go on the highway. Or in general? You could calculate engine RPM to rear wheel rpm through the gears. Running 2400-2700 rpm is a sweet spot for power and efficiency on the highway.
Too low and your screaming down the highway. Too tall and you are low in the engines power. Area and lugging the engine.
Sent from my iPhone using Tapatalk
I've been running 3.73s and 33 inch tires for so long that I grew used to how much the engine lugs. I am doing 60mph or so at about 1600 RPM - I shake my fist at the tractor trailers as they blow by me. I've needed gears for a while.
I used this site to figure out my new speeds and RPMs, it's a great tool.
3.73 (current) gears on the left, and 4.88 on the right. Looks like this would put me right where I'd want to be.
I've ordered 4.88 gears, bearings, etc for the rear axle. I'll get that one done then move to the Dana 30 front.
Is the 4.88 with 33’s or 35s?
Bearing Wear: Lugging puts high pressure on crankshaft bearings while they are receiving low oil pressure, potentially leading to premature bearing failure.
Internal Damage: Continued, severe lugging can lead to damage to piston rings, connecting rods, and can even crack pistons.
My 05 manual unlimited with the stock tire @72 mph 2032rpm
With 33’s @72 mph 1847
4:11 would correct for 33’s
4:56 correct for 35’s
Currently when on the flat its ok
But hit any hill I’m downshifting to maintain 65-68mph or passing.
Funny now that you know how to… you’re hooked.
I'll probably run 33s for the time being, but I may go to 35s. I'm not sure about running 35s on my Dana 30. I do have chrome-molly axle shafts, but I'd still hate to snap an axle.
You're right though, now that I've done gears once I'm ready to jump back in. I paid $230 for the ring and pinion, and $125 for all the additional needed stuff. Pretty cheap IMO.
I've finished installing 4.88 gears into the rear of my TJ, and so far so good! I'm only 40 mile in, and the break-in instructions tell me not to go too fast, but around town things seem great.
Setting these up were much easier than when I tried to setup my old used gears. I only had to run patterns three times before I got things right.
I've just ordered matching 4.88s for the front dana 30.
