looking for three inch lift springs
mrkltj
hello. iam lookin for a good set three inch lift springs for a tj new are used.
p.s this is a great site!!8)
If you want a good lift for cheap, pick up a set of front 4" coils and move your stock front springs to the rear. You can usually get a pair of 4" coils for as little as $99, sometimes cheaper if you buy used.
What I mentioned will do both, and you can sell the budget boost.
Be prepared to get longer lower control arms with any more lift than you have now.
how does this set up performe. does movein the front springs to rear cause any problem
on a side not i assume that your int he service. just wanted to say thanks for supporting are freedom thats awsome.
Veteran, thanks. A Jeep with front coils in the rear actually rides and flexes very well. You will need all the other stuff needed for a 4" kit, like shocks, TC drop or SYE, longer brake lines, etc.
