Duh! forgot to answer the question above!!
OK Bear with me as I attempt to give descriptions and possibly visuals. Don't have an image for this but Quadratec catalog has an exploded drawing in the brakes section. Looking at the exploded drawing and picturing the parts assembled, the rotor rides on the bearings which rides on the axle. They are free to rotate separately when the hub is unlocked. The hub assembly is screwed onto the end of the rotor and travels with it. Inside of the hub is a mechanism with an agressive pitched thread. Contained within the hub also is what Warn terms a clutch ring.
http://www.quadratec.com/cgi-bin/sg...QA=1&UREQB=2&UREQC=3&UREQD=4&FNM=00&x=76&y=29
The large outside teeth are always engaged to the hub. When the hub is rotated to lock, the clutch is moved onto the end of the axle and the inside set of teeth engage the axle locking the rotor and axle together. This allows power to be transfered through the front diff to the front wheels. Clear as mud? Hope this helps.
D 8)
