redrooster
Towing capacity of YJ
If you are going to weld the spider gears then you need to pull the carrier out of the housing. Yeah, I know it's not entirely necessary, but you don't want to get weld spawls all in your bearings and stuck to your gears. So pull it out and use some Anti spatter in the ring gear and bearings.
Here's where some people mess up: dont' weld the spider gears to the carrier. Weld the gears together. You should have a total of 8 beads run on the gears. Welding to the cast carrier will just crack or break.
Let it cool, stick it back in and stab on it!
