:-? Lifts and tires i need help!!!!
1075090
:-? I have a 97 Wrangler Sport and i cant tell which life to get. what would be better a Skyjacker 2.5'' or a Skyjacker 4''. the tires i was looking at were Super Swampers Radial TSL 33/12.5/15 or Conti Mud-Trac Radial 33/12.5/15. I know both will fit under the 2.5 or the 4'' lift but what would be best. I see most people with 4'' lifts and i know the new rubicons come with that, is that what i should go with. Thanks for all the help.
Chris
edited by: SilentJeeper97\', Jul 08, 2003 - 12:08 PM[addsig]
1075092
if you have the money to do it right go with the 4'' if not run the 2.5" with 32'' tires so you will have more flex..... and rubis have a 1'' spacer w/ 31s[addsig]
1075112
The Swampers run a little larger than most tires of a comparable size rating, they're the tire closest to the size rating you'll find. Run the 4" if you don't want to rub offroad.[addsig]
