lift kits
bizmarkee7
i am looking to put either 32" or 33" tires on my 03 sahara...is there a good suspension lift out there under $400.00...or does anyone else have suggestions on alternatives...[addsig]
1072652
What are you wanting to do with the Jeep? Keeping it on the road? Offroad? What percentage of each?
Budget boost, which is 2" coil spacers and new shocks, will work good with 32" tires if offroad performance is not a main concern. It will work offroad, just not as well as longer springs.[addsig]
1072660
im looking for something that i can still drive to class and work everyday...nothing too extreme just be able to do more trails than with what i have now...and also what would be the best way to fit 33" tires, i checked out the budget boost but that only supports 32"...also with budget boost what shocks would the good...i know rancho would be the best, but im still in college and am poor for right now...also what is the very next step up from budget boost as in price and quality...and as far as on-road,off-road use i would say 75% to 25%...thanks a lot for all your help...[addsig]
1072671
Too get something that will give you what you desire, you can try a budget lift like bounty said! Also incorporate a 1 maybe 2 inch body lift. You probably will be able to run 32's with no rubbing and better clearence (with 2 inch BL). 33's will fit but might rub a little.
As I was once a poor jeep owning college student, my advice would be to save your money, deal with what you got for now. If you want to improve on the capability of you rig do some simple mods. A bit more power from the motor can't hurt. sway bar disconnects on a factory ride height will do wonders for you rig! Do small things while at the same time saving the cash needed to perform a nice suspension lift with all the proper equipment, it will be worth the wait. I waited 4 years and was definalty worth it.
Johnny[addsig]
1072675
You can do a 3" spacer lift front and a 2" spacer lift in the rear with a 1" body lift and run the 33's that you would like to run offroad. If you are putting it in yourself it should be with the new shock about $400.00
Let me know if you are interested
1072746
_________________
the re bb kit is what i will probably get...should i get a kit with springs or can i buy them seperately... i have about 450 now to spend...thanks[addsig]
