texasjeepguy
Hello. Well, I have a 2002 Jeep Liberty with a 3.7 engine. About a month ago, I started hearing a ticking sound coming through speakers in my Jeep. This ticking sound can only be heard when the radio is in FM mode ONLY. It is an aftermarket radio (pioneer), but this radio worked perfectly for 5 months before this problem came up. I went ahead and installed to original radio, and it also has the ticking sound in FM mode ONLY. Well, I tried a noise filter, rewireing the harness adapter in the aftermarket radio, a new antenna, and I was unable to correct the problem. Well, I read an article that directed me to use a battery operated radio to check and see if the problem is being broadcast, and entering through the antenna. Sure enough, the ticking sound is broadcast 15-20 feet away via the FM mode. This sound is only heard when the engine is on, so I know it has to do with an engine component. You guys have any idea what component it could be. I already replaced the spark plugs, so it should not be the actual spark plugs. Any help would be greatly appreciated.
