bradleyheathhays
Member
Couple questions.
I'm replacing the bushings/shackles on the old '96 XJ leaf springs and I'm not sure how to go about disconnecting everything. Since the springs are under load I just don't want to jump into taking things apart on my first go round here. So do I just basically jack the rear end up so the tires are off the ground, then disconnect the front and rear ends of the leafs? At that point if I can get enough access to the ends I'm guessing I won't have to disconnect the springs from the axle.
And on the shocks.. Need to replace all 4 and need advice on a good brand/model. Basically my rigs always on the road and I just want a good quality OEM replacement...not economy and not heavy duty.
