kill switch
1073334
Don't know of any sites with actuall instructions... but I put one on my 67 stang. Just splice into the coil wire and run a switch to the interior. I havn't put one on my jeep yet but I plan on it. Tell me how it goes.[addsig]
1073335
Try This! Works Awesome.
Be forewarned though, that the write up is for
a 97 TJ and there are some minor wire differences
in the later models. Best to use the write up and your FSM
wiring diagrams to guide you in making the right connections.
Here ya Go: http://home.att.net/~email.id/ADESystem.doc
This system kills the WHOLE auto shutdonw relay! Nuttin' will
work in your jeep, Starter, Fuel pump. Injectors, ETc. Only
you can start it.
edited by: KAYBONE, Jun 26, 2003 - 03:59 PM[addsig]
1073336
It's easy to do yourself, you don't really need detailed instructions if you can do some minor wire splicing. Just locate the power wire to your fuel pump and wire a simple on/off switch to it. Just wire the switch inline with the power wire. If you're having trouble finding the power wire you could ask someone on here who might know what color wire to look for or you could just use a test light to find it. The good thing about running it through your fuel pump is that no one can bomb start your jeep (if it's a manual trans.) because it'll have no fuel.
edited by: Craig, Jun 26, 2003 - 08:17 AM[addsig]
1073440
Are you doing this to prevent it from being stolen? I put one of those battery quick disconnects on mine-- takes 2 minutes to install and does the same thing-- screw out the copper top and she wont start! [addsig]
